- 4 Aug 2007
- Wilds of suffolk
We have 3 inverters. Two are regular inverters and one is a hybrid. The 2 regular convert PV DC to AC send the electricity to the fuse board. The hybrid has the sensor on the AC cables coming from in from the grid. The Hybrid does the decision making and charges/discharges the batteries etc.
I am not technical but it seems to me that an extra standard inverter can easily be installed as long as the fuse board has an empty slot
Thanks!
I guess that might work for me although my system isnt wired into the CU since its while house UPS, main feed is diverted into unit then back to CU
Might not stop me having another though
Might have a measure up see what could realistically fit and likely generation and ROI etc
