Hey all,
Been a long time since I did a full build (2013) so massively out of date with current trends and recommendations so would really appreciate some advice and direction. I usually do a refresh after about 5 years but well past that now (was planning to do it before the GPU / COVID situation hit), build hasn't been touched bar upgrading the graphics card midway through the refresh cycle for this one!
Current build:
i7 3770k @ stock 3.5
32gb RAM
GTX 1080
Gigabyte GA-Z77X-D3H
Corsair 750W PSU
I'm not planning on using anything from the existing build (I'll pass it on to my missus to replace her weaker one) but just showing the level of build I usually aim for (good high performance vs reasonable cost). It is still holding up fairly well for most of what I throw at it bar some modern games but want to get some more performance out of my build. Usage will be programming, general heavy PC use and 1440, 144hz gaming. 90% of my usage will be linux based, I think that drivers between AMD / nVidia are fairly even now but thought it worth mentioning that windows will definitely be the secondary OS. Will obviously want fast storage for the operating system and probably a secondary which can be a normal SSD (got some spinning metal in my current one which will need to be replaced!). Case-wise, I'm a fan of fairly plain classic black tower cases (got a corsair 300R currently) and it'll be stored under desk so fairly boring on that side but something with good airflow to keep noise down would be great! Budget is around £2k but can stretch higher if it makes sense!
Hopefully that should help with any recommendations people might help but let me know if I missed something! Thanks very much!
Current build:
32gb RAM
GTX 1080
Corsair 750W PSU
