Okay so will preface by saying I bought the components and having a local company put it all together for me as I was reusing some old components and I'm useless, but seems like there's some issues...
I have:
Ryzen 7700x
Strix b650e-f
6000mhz patriot viper venom 32gb cl36 (ram bought from competitor)
The company rang today to say there's an issue. Basically the pc turns on, but there's no video output so can't get into bios or anything and the mobo is showing dram problem apparently.
What are the chances of dead ram, or any compatibility issues you can see with this setup? They've ordered some very very basic test ram, but looks like I'm going to either need to order replacement Patriot RAM or buy a different brand? The website says its EXPO compatible apparently so thought it would be okay (?)
Could it still be a mobo issue? I'm trying to prepare and order replacement/correct parts ASAP to save downtime as I need the machine for some work.
Thanks!
I have:
Ryzen 7700x
Strix b650e-f
Thanks!
