Which is likely to be the better card for £. They all sit around the £400-450 bracket.
I'm gaming at 1440p, from benchmarks it looks like the 6750XT just gets an edge over the 3060Ti, but some reviews suggest with ray tracing or DLSS that the 6750XT don't perform as well as the 3060Ti.
www.techpowerup.com
The 3060Ti is also a bit of an older card, although the refreshed 6750XT seems to be quite power hungry.
Any thoughts on which way I should lean towards.
For reference it'll be running in my new AM5/7600X rig.
MSI Radeon RX 6750 XT Gaming X Trio Review
MSI's Radeon RX 6750 XT runs whisper-quiet thanks to a well-tuned profile that maximizes the efficiency of the triple-fan, triple-slot thermal solution. Performance is also good, making this an excellent choice for all gamers using the 1440p resolution.
