Solar panels and battery - any real world recommendations?
I would have assumed you having scaffold up and running may have also been something they'd have liked to piggy back on, oh well, like you say :)
Yup, even gave the guy the name of the roofer who sorted my stack out when moved in. Hey ho at least I got an audit trail now if it ends up causing damage to my property
All up and running, just need a visit in a week or so to fit bird blocker (some clips needed due to panels not having the lip on one edge) and get the car charger hooked up for solar excess.
Had to run off before he finished, but had a cheeky look while at work and saw it chugging away with pretty decent production this late in the day and with the shading issues at this time of year:
Total production today was 5.3kwh, and the system only went live at just before midday so that’s pretty cool for a winter day!
Panels all up:
Installer sent me this shot of the roof too… makes the panels one house over look a bit puny lol.
@Zeeflyboy That depends, on my SolarEdge system it was as simple as getting the API key and adding it to PV Output, but with others its more complicated.
Just from a brief look, it seems that there isn’t anything that straight forward for Solis.
I did find this which scrapes the SolisCloud and can then send to pvoutput https://github.com/dkruyt/ginlong-scraper
I believe there is similar stuff for HA too which is something I’ve been meaning to look into.
When I can figure it out there is also a modbus thing you can do with a wave share device to make the Solis inverter fully controllable from HA and then control charge rates etc with Solar forecasts and so on… will probably take me a while to wrap my head around how exactly one achieves it (ignore the name, it supports some Solis inverters too) https://github.com/wills106/homeassistant-solax-modbus/
hows the weather looking with you, to test out that new shiny system??
19kWh batteries actually - nobody charges their EV from batteries so your logic s completely flawed!
FYI. I have an electric golf, 26kw batteries for the house and a 14.4kw solar system.
I charge the Golf from the batteries at least once a month. If you are out all day in the car, the charging has to be done when there is no solar production, hence using my house batteries to do this.
To prolong the batteries of the Golf I normally only charge it up to 80%. Yesterday I had to do 126 miles so the Golf was charged up up to 100% overnight from my batteries so I would not suffer from "range anxiety".
Last month we generated 596kw. It was a good January but last year (which was poor) that figure was only 508kw.
How much did you generate in your best ever month? Assuming you had all those panels last summer?
Here is the answer.
Originally we installed 17 x 235watt Sanyo's in October 2011.
In September 2021 we then added 4.8kw on the east roof and a further 5.6 on the south roof.
The spreadsheet has been adapted to the expansion, so the first set of columns just relate to our original panels. The last 3 are new ones on the East roof and then the south roof with the grand total on the extreme right. Highest ever day was June 14th when we managed 87.7kw. Yearly target was 14,000 but last year was a good one. Still hoping I might get 2,000 one month although no idea what to do with it other than help out the grid
2021/2022OutputTarget% of targetActual ReadingMeter ReadingPlus/Minus KW
Year 11for targetfor target
October
276.9​
299​
92.61​
43809​
43831​
22.10​
240.2​
364.4​
881.5​
November
216.5​
179​
120.95​
44025​
44010​
15.40​
154.3​
290.0​
660.8​
December
96.2​
132​
72.88​
44122​
44142​
20.40​
66.6​
134.5​
297.3​
January
172.3​
153​
112.61​
44294​
44295​
1.10​
108.3​
227.7​
508.3​
February
249.4​
220​
113.36​
44543​
44515​
28.30​
199.9​
329.0​
778.3​
March
394.4​
398​
99.10​
44938​
44913​
24.70​
372.3​
553.7​
1320.4​
April
493.8​
500​
98.76​
45432​
45413​
18.50​
527.4​
679.1​
1700.3​
May
499.1​
513​
97.29​
45931​
45926​
4.60​
516.4​
679.2​
1694.7​
June
539.8​
536​
100.71​
46470​
46462​
8.40​
585.2​
720.1​
1845.1​
July
578.9​
510​
113.51​
47049​
46972​
77.30​
636.7​
772.7​
1988.3​
August
542.8​
472​
115.01​
47592​
47444​
148.13​
520.1​
692.6​
1755.5​
September
381.8​
389​
98.14​
47974​
47833​
140.90​
377.6​
487.0​
1246.4​
Total
4441.9​
4301​
4305​
5930​
14677​
I should have said most people don't charge from the batteries because usually they have a cheap EV rate like Octopus Go.
A lot of people don't have large amounts of storage capacity either so won't have the capacity to support the house and the EV from batteries.
The mileage I do, I'd need a minimum of 30kWh batteries just for that purpose alone.
That's great generation, what size arrays produced that, are you on 3'phase as well?
Edit: you've answered above !!
