- 23 Nov 2014
- The Cronx
Surely you should be suspicious of Covid instead?
are you suspicious of seatbelts because many people die in car accidents even if they are wearing a belt?I’m suspicious of the vaccine when so many people are still dying vaccinated.
Have to admit I now don't think of covid at all or take any precautions. Probably happened over December ish.
Now the only interest I have is getting my 20 pounds a month for doing the blood tests from the ONS.
I think I've been given 700+ pounds so far
This weeks update, hope it doesn't go up too much.![]()
Looks good, wait a minute... ENHANCE!
Ah so because we don't know how bad something could be long term it's not worth taking any precautions, even though you know exactly how bad it is in the "short term" (up to nearly a year after the first covid cases, before the vaccine).Reciting memories you have isn’t good data, you’re as much in the dark about long term illness as I am regarding covid.
Chris witty said 99% survival rate in the uk. Of that 1% people would be hospitalised and a smaller % would die.
who are the people most affected and of those people, are a high % of those VD deficient?
Everyone is back to hugging one another and socialising which is lovely to see.
The vast majority of people are vaccinated, so of course most people dying would be vaccinated, I'm sure you're not actually that unintelligent right?Reciting memories you have isn’t good data, you’re as much in the dark about long term illness as I am regarding covid.
I work in a school, hugging is a daily occurrence between colleagues.Hugging people is very much not normal (aside from between people who are friends/family outside of work) in any business I've worked in, especially these days heh.
I can literally remember every instance in the last ~20 years it is so uncommon.
www.hartgroup.org
How anyone with any sort of intelligence can doubt the effectiveness of the vaccines is beyond me.
Oh and some time in the distant future, all those vaccinated are going to suffer some terrible fate.
You shouldn't keep that sort of info to yourself, spill the beans we have to know!!!!!!!!![]()
So how affective are the vaccines really?The vast majority of people are vaccinated, so of course most people dying would be vaccinated, I'm sure you're not actually that unintelligent right?
I can only assume going off a lack of media coverage that hardly anyone at all has long term harm from the virus that got over it. Witty said most would recover at home, 99% of people and this was before a vaccine come about, the 1% would end up in hospital and a smaller % might die. Ive not seen anything on the % of people with long term affects. They only talked about long covid that should go away after a while, some talked about lung damage but I've not heard anything about it for ages.Ah so because we don't know how bad something could be long term it's not worth taking any precautions, even though you know exactly how bad it is in the "short term" (up to nearly a year after the first covid cases, before the vaccine).
Also you seem to be misunderstanding what "survival rate" is, as you state that 1% of people would be hospitalised and a smaller amount would die, survival rate is exactly that, the expected survival rate, if you've got a 99% survival rate expected then by definition you expect 1% to die, it doesn't even attempt to go into how many people will have complications as that's a different set of stats that are often not understood until years or decades later (but we already knew some of that within months).
Polio had a 90-95% survival rate for those infected, but a very large number of the initial 90-95% who survived had complications that ranged from the mild, to the extremely severe (partial or full paralysis, loss of limb function, need to have the classic "iron lung" devices), and a lot of the survivors eventually died of complication from the initial infection.
In much the way you can survive a car crash, but be left in a wheelchair, or you can survive stepping on a land mine but lose a limb.
Or as a more extreme but common and very related example, from memory HPV (herpes) has basically no fatalities from the initial infection, but we know it can and does cause cervical cancer which can/does kill you and that a vaccine will prevent that, so the survival rate from it may be 100% short term, but long term at least half the population is at a significantly increased risk of death from something that we can now trace back to it (after decades of research).
I was till I caught it early 2020.Surely you should be suspicious of Covid instead?
