So, the last watercooled PC I built was this one;
Things have certainly come on from heater matrixes and pond pumps, and I want to build a nice looking custom looped system.
Parts I have;
Asrock X670E (white PCB, ATX)
Ryzen 7950X
64GB RGB DDR5
Seasonic 1000W fully modular PSU
MSI 4080 Suprimx
Thinks I like;
www.overclockers.co.uk
What I've done so far;
The case can support 280mm radiators though.
Things I don't know;
Is the reason behind using a res so that the system can bleed itself?
Should I do a single loop and pass through each rad one after another?
How do people do the nice neat bends?
What about fittings - are they universal?
![heater_matrix.jpg](https://tackycheese.net/images/old/comp/heater_matrix.jpg)
![not_kinked.jpg](https://tackycheese.net/images/old/comp/not_kinked.jpg)
Parts I have;
Ryzen 7950X
64GB RGB DDR5
MSI 4080 Suprimx
Thinks I like;
![www.overclockers.co.uk](https://img.overclockers.co.uk/images/CA-79K-LL/455e7fecb883101390f237d894a3207d.jpg)
Lian Li O11 Air Mini, Midi-Tower, Tempered Glass - White
Order Lian Li O11 Air Mini, Midi-Tower, Tempered Glass - White now online and benefit from fast delivery.
![www.overclockers.co.uk](https://assets.overclockers.co.uk/assets/ocuk/images/favicon-32x32.png)
Based on your choices we estimate the heat load (of the liquid cooled components) to be 830W.
Therefore we recommend the use of EK-CoolStream SE 240 (Slim Dual) on pedestal right and EK-CoolStream SE 240 (Slim Dual) on Position front and EK-CoolStream SE 240 (Slim Dual) on Position bottom of your computer case.
