Man of Honour
- 21 Nov 2004
Actually needed an hour of heating this morning upstairs. Will be interesting to see how usage compares to last month.
Yep.Just gas?
Ok this is weird. I've just received a huge credit into my octopus account. I'm now over £1k in credit! I've dropped them an email as I'm not sure what's going on....
Anyone ever had this?
Hi folks. Quick question which is probably as good in here as setting up a new thread.
I've just moved into a new place. My heating is set to be very low during the day, as I'm usually out and about when not working from home. However, I work from home 2-3 days a week, and obviously like to be a reasonable temperature while doing so, but only really need one room to be warm when that's the case.
Is it cheaper to switch my (gas, combi boiler) central heating on from time to time through the day, or to buy and use an electric oil radiator to heat only the room in question?
I'm fortunate in that I'm not vastly worried about money, so if there's only a few £ a month in it I won't bother buying the oil radiator, but if there's a significant saving to be made then obviously it's worthwhile. Thanks!
Where is the thermostat? Is it in that room? If not I'd consider using a separate heater, closing the door and leaving the house thermostat lower.Hi folks. Quick question which is probably as good in here as setting up a new thread.
Bear in mind that gas is something like 4-5x cheaper than electricity, so I'm not personally convinced that an electric heater makes sense over gas.
Its about 3.3x cheaper, but thats also before efficiency losses, if you assume 90% efficient boiler then thats 3x.
Really the main thing is how efficient is the house at containing warmth. If its good then heating the whole house might not be that bad, but if its low then its almost certainly better to constantly heat a small contained space.
OFC what happens later in the day counts as well. If they want a high heat across whole house then the expensive part, getting the house up to temp is still going to happen later.
