240V fans that have the same CFM as a 12V fan are much more expensive which is not what I expected. It would be much easier thoughBest off getting something that's 240volts out of the box.
I can't wait to need to add back ventilation! At the moment close any internal door and there's a steady draught under it, which changes depending how windy it is outside. And this is after filling in the random holes into the cavity/vented floor that don't align with an airbrick. What's left seems to be a lot of tiny holes, and only findable in high wind conditions. Which I hope to replicate with the blower door.Careful with this, you're effectively sealing off all the ventilation in your house. It might not be intentional ventilation, but removing it without carrying out the correct checks means that your house could well become a nightmare to maintain in terms of damp and mold.
Thanks that's a search term I didn't know.For extra resources, search "room integrity testing" - this is more for fire suppression systems but it's the same principle and you'll likely find a ton of useful info.
I've tried joss sticks for smoke which don't make enough; those smoke pellets might make a little too much![]()
