- 29 Aug 2010
- Cornwall
So I'm hoping to get an AM5 motherboard soon for a new X3D CPU.
I don't know which one I want to get. I don't know if I should go X670 or B650.
Most of my motherboards in the past have been Asus, so I was thinking of going down that route and probably picking up a Strix board of some kind.
But then I got to thinking, if my hope is to keep the motherboard for a while and make use of the hopeful longevity of the AM5 socket maybe there are some thing I need to consider first. Maybe I need to look at PCIe 5.0 and get as many of those slots/NVMe connectors as possible, maybe I should be looking to get USB4. But I guess another important factor is, will the board get the required BIOS updates to support the new CPUs (e.g. 8000 series, 9000 series, etc.)?
So since I've only really had Asus boards in the past and have mostly gone Intel where it's often been 1 and done as far as CPU generations go, I was wondering is Asus a good brand to go for? Will they get the required BIOS updates to support the new chip and support them well? Is there another brand that historically has been better for releasing BIOSes to support the new AMD CPUs?
Are there any "killer" motherboards this time around I should consider before I just go and buy an Asus Strix board?
