MSI A1000G PCIE5 - Am i being stupid?
8 Jan 2010
On MSIs product page it says for graphics cards with 3x 8 pin, plug three individual cables into the power supply pcie which I would expect.
Then looking at the cables they provide, they only provide 2 6+2 pin pcie cables. There is also a 16 pin to 6+2 as well.
How am I meant to plug 3x 8 pin in without using the 16 pin as well as the standard pcies???
Also why isn't there a 16 pin [PSU] to 3x 8 pin [GPU] rather than the 2x 8 pin they provide?
It's the same with this new bequiet atx 3.0 pure power, they are only providing two cables. It seems they have totally forgotten about graphics cards with 3x 8 pin?? I don't get it.
Yes, the graphics card end has 4x 6+2 but the power supply feed is only two cables, and its always recommended to put all 3 separately for 3x 8 pin.
Especially since msi says to plug three into the power supply and they only give two cables...
Solved the Bequiet one.. it uses two 12 pins on the power supply side. Msi still using 8 pins, so doesn't make sense to only provide two 8 pin cables.
I think the non PCI-E 5.0 version has enough ports to connect 3 PCI-E 8 pin cables and 2 EPS 12v, but the PCI-E 5.0 version does not, so you'd have to daisy chain one of them. They seem to assume that if you buy the PCI-E 5.0 version you'll have 2 EPS 12v and be using the 12/16 pin for your graphics card. Which I guess makes sense in a way, because you might as well buy the non-PCI-E 5.0 version for an AMD graphics card or an 8 pin NVIDIA.
Hmm but there is benefits to all cards with these graphics cards, it's not just the 16 pin.
I don't understand why they can't make a 16 pin to 3x 8 pin cable, or is it thst it'll be limited to 450w (150w x 3)? Why provide a 16 pin to 2x8 pin then? I don't get it
Especially since they could do a 3x 8 pin to 16 pin adapter why can't you do the other way around?
My impression is that they bundle the 16 pin to 2x8 pin just on the off chance that someone is using a 3 PCI-E 8 pin graphics card and needs that extra cable, so with that cable and one of the 2 bundled PCI-E 8 pin cables, you'll now have enough, but they seem to think that's an unlikely scenario and I'd probably agree IF someone is making their purchase decision in a 'simplistic' way and knows in advance which graphics card they'll have.
Only having 2 PCI-E 8 pin is maybe less inclined to overload the cable pins and will spread the load of a 3 PCI-E 8 pin card between 2 independent cables (the 12/16 pin and 1 of the other bundled cables).
In the marketing description of the PSUs it seems quite clear they think the non-PCI-E 5.0 version is for RTX 3000 cards with 8-pins and the PCI-E 5.0 version is for RTX 4000 cards with 12/16 pins.
Hmm makes sense, it is odd though that the 8 pin they then give is a pair, so you'll have 4x 8 pins, none of these psu provided cables are good for cable management for 3x 8 pin
Yeah, it's not ideal, but then 3 independent cables (on the non PCI-E 5.0 version) isn't ideal either, that leaves lots of empty connectors and a mess of cables.
I have this PSU (decided to future-proof myself for any later upgrades) and thought I'd be able to use the 16pin to 2x8pin cable, to power my 2080Ti... But when powering on, I get the message "please power down and connect the pcie cables".
I assume I'll need to run the separate 8 pin cables..?
I assume this was all resolved, but for anyone discovering this thread. They provide a 12VHPR to 8pin PCI-e cable. So even with a motherboard that requires 2x8 pin, you still have 3x individual 8pin cables.
