I'm more concerned as to why it burnt up the neutral pin, not the live pin.
Is the socket wired correctly even?
If that's where a bad connection was that's where the heat will be generated
Well yes that can indeed be the issue, just seems a little odd to get a loose connection on the neutral pin unless someone's been jamming something into the socket![]()
As said, potentially poor quality sockets, if you've ever bought a cheap extension cable you might have noticed that it's either a lot stiffer or a lot easier than normal to push a plug into it, this can happen with normal sockets.Well yes that can indeed be the issue, just seems a little odd to get a loose connection on the neutral pin unless someone's been jamming something into the socket![]()
It’s AC. Doesn’t make a differenceI'm more concerned as to why it burnt up the neutral pin, not the live pin.
It's nothing to do with the consumer unit it to be fair.How good is your fuse board and trips etc if this can happen?
I'd be getting a decent electrician in to do a safety check on the house and appliances. I get them as a tenant, we had quite a lot of remediation needed on three last one.
Probably not cheap but it's not worth risking a fire.
