any news on a release date at all?
Gonna sell out instantly i bet like when the T30 launched. Took me a while to get 9 of those for a radiator config back in the day.Last word pre orders middle of Feb, release end of Feb/ very early March.
D30 fans all we have is "March".
Hi Hostile_18,
The NV7 will be launched end March/begin April together with the D30 fans ( at OCUK ).
Phanteks team
Phanteks announced the NV7 at CES 2023. Out February, anyone here tempted?
Next Gen Cable Management - Phanteks NV7
The Phanteks NV7 is a case that will do everything and it has the absolute best cable management systems I've every seen. You have to see it to believe it! ...www.youtube.com
The new fans in question out March. Based on the Phanteks T-30's. They can be daisy chained like the Lian Li Uni fans. They are available in two skus exhaust and intake so you can always be "pretty" side up.
Case Fans Have NEVER Looked This Good!
The Phanteks D30-120 might be the best case fan and radiator fan I've ever seen, provided you like RGB. They've taken the amazing T30, added an integrated H...www.youtube.com
Ok guys I've got some bad news;
Where did you hear that, did they reply on this forum or is that a quote of an email?
Any idea when pre order will be available on here?
Might get them before i go on holiday then or get them while im in the US if somewhere like Best Buy sells them.Ok guys I've got some bad news;
I think it'll be between the NV7 and the O11D Evo XL:Phanteks announced the NV7 at CES 2023. Out February, anyone here tempted?
You'd be better off having the 2 rear fans as exhaust, even nvidia showed it that way when they introduced the 'pass through cooling' design on the 30xx founders editions.So since we will likely need to know what version of the fans to get and likely with little time, with an air cooled GPU is this the best configuration? Or possibly with the rear two exhaust? Or something completely different?
It would likely cause more issues because it would be fighting against the natural flow of all the other air, if nothing else it would cause turbulence and as such noise. The only way to find out is to try it but I wouldn't do it personally.My line of thinking is the radiator will have a fresh supply of cool air from the back and straight through the radiator. Also if it was exhaust the top left corner top and back fans would be kind of working against each other?
Any news on pre-order?
