 - 20 Jul 2007
 - A sunnier or damper area than Ron-ski....
Hi all,
Have been setting up my new Ubiquiti network around the house and have just installed a U6 LR outside.
Whilst I've been amazed by the U6 Pros I've installed in the house and outbuildings, this seems somewhat underwhelming - indeed, I'm not even convinced my phone is actually using it, rather it's picking up the fainter signal of U6 Pros in the house or garden room.
Can anyone give me tips on how to diagnose/fix this? Standing right in front of it I get a 'half bar' signal, hence I reckon it's the U6 Pro inside the garden room that it's connecting to?
Set up is:
- UDM SE in the house
- 6 x U6 Pros - I think most of these are connected by PoE directly to the UDM SE - however a couple are connected through non-ubiquiti switches to it and then have PoE injectors
- The U6 Pro in question is connected through three switches unfortunately - UDM SE to a 24 port Netgear Switch next to it > this then runs to an 8 port Netgear switch in the Gym > this then runs under the ground to the Garden room to another switch, which then connects to the U6 LR with a PoE Injector.
I know this isn't optimal, but not an easy way to direct run a cable without a JCB...
Could this be causing any of the problems? Certainly it seemed to be discovered fine and adopted into my Unifi network?
Any help appreciated!
Set up is:
 Set it and forget, then if you start to notice some issues you can always change it by hand again.
