List your DIY hacks
5 Aug 2013
Shropshire
After the thread where poster couldn't get cable through a hole I thought we need a hack thread so my first.
If you have or come across metal wire coat hangers grab them and hang them on a nail in garage etc.
I have used one straightend out for numerous job - threading cable is one of them. - If you are running any phone or CAT cable hold the cable in one hand then pull the sheath towards end so it stretches and wires go instide sheath - you then put wire in and tape it together then just poke wire through hole and the cable will follow it so keep pushing till wire drops out the other end or stops -go round other side and gentle pull through.
Also used wire to poke up a hole in ceiling /soffits to loft and it should go through insulation and go up and find it sitting there.
Also make S shaped hooks to put things on and hang from hooks-nails whatever.
Cable Ties
If you use these and like me you cut corner off packet then pick them up from shelf by wrong end they all slide out of corner- Next time put packet flat on table then from 1/3rd way in from edge cut a slot along middle of packet for a 1/3rd then all you do is put your fingers in slot and pull one out.
Scrap copper/plastic pipe
Screw some pipe clips to wall horizontally -press pipe on and there you have a holder for all your spray bottles of car detailing stuff etc.
Scrap soil pipe
Cut one end at 45deg -drill hole at top then screw to wall - I keep all my threaded rods -electric trunking -bars -anything that you need out of way.
Got one for all my long SDS masonary drill bits.
Thin Galvanised strip bars with holes in.
bend into a U shape then bend ends 90deg out ward so if you screw them to joist in garage you have somewhere to store copper pipe -trunking etc - you will need 2 at least or more if you have long pipes.
Those magnet bars that Lidl sell come in handy screwed to wall.
Can't think of anymore now,
I know it's not quite a hack, but the best thing I've done is get a 3d printer!
All the pipe, storage and other stuff you mention above becomes two clicks and a few pennies of filament - I've organised thousands of things around the house with it (literally 1000+ prints in the last couple of years!)
1) Metal clothes hangers, I had 20 back in 1980 when I had my first house and last year I ran out so bought another 20 :)
2) Cocktail sticks for plugging up loose screw holes
That sounds like more of a bodge than a hack.
Well if you take a door off and a couple of the screws are very loose a cocktail stick will now give you a strong bond.
Sometimes on a new job as careful as you are the hole goes wrong. Once again a cocktail stick will save the day and that curtain pole will stay up.
I suppose it is a bodge though but a great tip.
Out of interest, what would be the 'official' way of repairing an oversized / damaged screw / rawlplug hole such that it can be used securely for a future screw / rawlplug?
Never thought of it but as a young man back in 1980 working on my first house I had to remove a lot of screws.
To put them back tight I was cutting up cardboard which eventually became wood shavings then cocktail sticks.
Well his bodge at 8 minutes is basically filling the hole with a smaller rawlplug that only holds the screw at the top end of the hole, his bodge even falls out if he removes the screw.
Using cocktail sticks you could force them down the outside of the rawlplug (or inside it) and the tight fit will be all the way down the hole.
Interesting stuff.
My issue in our current house is that every wall is plasterboard with dot and dab over concrete block, with a void between the two. Means you don't generally reach the concrete - and if you do there's a decent chance it will make the drill bit skip around and completely ruin the straightness of your hole.
I wouldn't do it for anything taking a lot of weight - but I have taken to (when I remember - I am not a frequent DIYer) using those metal plasterboard fixings which screw into the plasterboard and spread the weight over a wider area. They're rated for like 25-50kg each, which is surprising!
Pretty sure that was a Dragons Den thing that Debra Meehan is making a lot of money out of.
These are the ones I mean:
Thought they'd been around for longer than Dragon's Den to be honest! But maybe she's selling a newer better version?
Just seen these, which look good. Designed to ensure you're biting into the concrete. But nearly £1 per plug!
At work I used long screws that went into brick/blocks behind plasterboard then made up a spacer to stop plaster pulling -we didn't want the things we hung coming off.
When I moved to a renter once and had to hang my gun cabinet I drilled two 2" holes in plasterboard then mixed up a runny dab mix and squirted in lower hole till it started to run out -taped it over then filled from top hole. put filler on hole and sanded -perfect- I then used long bolts into wall behind.
When I left just put filler in holes -sanded and painted and you couldn't see anything had been on wall.
