- 17 Mar 2017
- Manchester
Hi,
So I have had this GPU since release and all has been well however I have always had it at 80% power limit and the hotspot generally reaches a max of 90c.
But after seeing others post about the hotspot on the Ichills has got me a little concerned as to whether I should get this returned to OCUK because after testing it today at stock 100% power settings and even a more aggressive fan curve when this GPU is reaching 445w I am seeing the hotspot peak at at over 101c regularly.
Now as far as I am concerned I know some will say this is normal behaviour but when the core is not going over 78c that's almost a 23c delta and 100% a contact or paste issue as one user on Reddit has repasted his and now he's not seeing more than a 15c delta so you would say poor manufacturing on Inno's part or poor assembly more like.
Now I am not prepared to strip down a £1700 GPU no matter what, As far as I am concerned any product costing this amount of money should be built properly or assembled properly, I am more concerned about the longevity of this GPU if I was running it at stock in a very good well ventilated case and we are currently in the middle of winter in the UK so this is going to get worse in the summer.
Anyone know how long the process if I send this back to OCUK, Is there a faster option or any advanced RMA on Inno's part if dealing with them or is it better to stick with the retailer?
Thanks in advance.
Thanks in advance.
