Caporegime
- 7 Apr 2008
- Lorville - Hurston
Hi. i have just got my first fix done on my electric and looking for some advice on which plastering method to use.
I asked my electrician and he told me that wet plastering is what i shoudl go for as all the socket boxes he installed sit flush inside the brick wall when he did some chasing.
His worry is that if i go for using a plasterboard, the plasterboard will come out thicker than the existing plaster i have(looks to be an old school wet method) as to aply the plasterboard to the wall, you do so using dot and dab which creates a gap between the wall and the plasterboard.
Electrician doesnt wanna go back and cut stuff up again adding say a extension column as its more work etc again and he just done chasing etc into the main brick work and i kinda agree with him but wondering if there is other ways of using plasterboard as its quicker to apply and cheaper too.
Walls in question
20230223_103004 by Jon Richy, on Flickr
20230223_102950 by Jon Richy, on Flickr
20230110_103707 by Jon Richy, on Flickr
Walls in question
