- 29 Aug 2010
- Cornwall
So I've just had to RMA some RAM and I don't think it was the first time.
Are there any common reason for a stick of RAM dying?
The Motherboard is Fatal1ty AB350 Gaming-ITX/ac and the RAM is Team Group Dark T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz.
It always seems to be the RAM stick nearest the CPU socket (from memory, pun sort of intended).
It's not overclocked, it's just using the XMP profile.
Could it be a fault RAM slot on the motherboard? Could the CPU cooler be blowing warm air onto the RAM stick and causing it to overheat (seems unlikely)?
Overclockers have been really good, but I'd rather it not keep happening.
Getting a new mITX motherboard would require a new CPU too, which is getting quite expensive for what I use the PC for so I'm hoping there's something I can do.
Any ideas?
Any ideas?
