- 26 May 2022
- UK
Is there any screws on the bed to line it up with? some printers have them which makes it easy. Otherwise you could maybe add two metal screws and nuts (washers as well?) to the corners on the back. Just the right size that sheet leans on them for alignment.A plastic scraper would be totally useless getting prints off the bed.. Anyway hopefully now scrapers and hammers will be a thing of the past as the magnetic plate came today and its on. Its Just a shame I haven't anything to print atm.
I was a bit worried that it would move about when printing, but the magnet is really strong, I cant move it when its magnetised on. So getting it straight when putting it on is a bit of a pain as it wont slide at all.
