Especially when that extra capacity is achieved by having 2 memory ranks per channel instead of 1. This is harder on the motherboard and the memory controller, generally causing more frequency loss and OC troubles than it's worth on DDR5.Do you use more than 32GB ever? If so get 64GB if not get the lower latency 32GB. No point buying extra capacity if you ain't gonna use it.
For example on most of MSI's X670/E boards they have EXPO profiles validated up to 6600mt/s with 1DPC 1RPC but only 6000mt/s with 1DPC 2RPC. (DPC = DIMMs per channel, RPC = Ranks per channel)
There was a YouTube video saying you should really really use 6000MT/s CL30 (not 36!), and the difference is massive can be massive. Ryzen has always been very latency sensitive. Let me try and find the video.
CL doesn't have a huge impact by itself. You get much larger latency and throughput differences from other factors like the infinity fabric clock and the memory controller clock. The box timings on a kit can sometimes indicate what type of memory chips it has though and that can be important.
