Hi All,
First Build in ten years so i am splashing out, but also trying to reduce the cost. The new AMD chips and the 40 series GPUs which have gut punched my budget coming out pretty much 40% more than i orginally planned.
I am looking for options that i could possibly consider. i have a few things that i really want and i am willing to pay the extra for.
i am very near having a list i am ok with , but may wait a month or so to see what the 7800X3D brings to the table and if prices in generaly across the board come down a bit.
so what to i need it for? i do a lot of 3d games work, UE5, mostly modeling and some odd bit of rendering, i play some games. generally i spend quite a bit of time on my PC, so want a good rig.
atm i have a 2k monitor but want a wide screen 4k one when i win the lottery.
Here is the list. I cant quite believe its this high, but hey, its the over inflated PC market these days.
things in Orange i kind of want / have settled on. things in green i am undecided on.
Case Lian Li O11 Air Mini - Black
CPU Ryzen 9 / 7950X3D
RAM 64gb Kingston FURY Beast RGB 64GB (2x32GB) DDR5 PC5-44800C40 5600MHz
GCard Gigabyte GeForce RTX 4080
PWR Supply Existing PSU Seasonic 850 focus ( no cost)
CPU water cooler NZXT Kraken Z63 AIO CPU Water Cooler with LCD Screen - 280mm
Motherboard Asus ROG Strix X670E-F Gaming WIFI
HDD M2 2tb Samsung 990 Pro 2TB M.2 2280 PCI-e 4.0 x4 NVMe 1.3c Solid State Drive
WINDOWS 11 Pro
Optional
Noctua fans 120 x5
Noctua fans 140 x2
Fan controller NZXT RGB & Fan Controller
Total so far 3.4k
Orginal budget was 3k
so things i have considered are
Getting a cheaper GPU, i have considered somthing less but the 4070Ti i think wont help with 4k gaming when i go that way, i'd rather get a 3090Ti for more Vram.
Getting a cheaper Processor, but as i need it mostly for 3d work and gaming its a bit tough to decide on which one now. the 7800X3D will be cheaper and better for games if i was only doing that. but it would not be as good for 3D rendering / video editing. i could go last gen CPU
Reduce the ram to 32gb but kind of want 64.
get a 1TB SSD
using my existing PSU for that saves me £250
i did consider a B650 Mobo but have settled upon the X670E for about £70 more.
kind of want the Kraken just for asthetic reasons and keeping and eye on temps.
I also want a quiet PC so will replace the fans with Noctua ones for the AIO and case
Anyway there it is, i am probably going a bit nuts but i only buiild a PC every 7 - 10 years
Thanks, any suggestions i could consider would be great or if you think somthing could be better let me know.
Thanks
Paul
WINDOWS 11 Pro
Optional
Noctua fans 120 x5
Noctua fans 140 x2
Total so far 3.4k
get a 1TB SSD
Thanks
Paul
