Dishwasher Tripping RCD
20 May 2007
We have had several instances of the RCD tripping and although short power outages aren't uncommon as we live quite rural, it was just the lighting and sockets to the kitchen
I appear to have narrowed it down to the Dishwasher and a minute or so into the wash programme (need to check if any wash programme) it trips the sockets and sometimes the lights in the kitchen
The kitchen and electrics are less than 18 months old, including new Consumer Unit and I'm pretty certain it's the Dishwasher and then likely the heating element
Before I order a replacement part is there anything i can do to check if it is or anything else I can try to confirm if it is the element or not?
Cheers
Yep, cold rinse, no problem and completes
Any programme needing heat, it trips
Thanks!
Will get an element ordered now ........
Have you checked the plug of the dishwasher and the socket on the wall for arcing? There was a recent post where a poor connection caused tripping. I do think you've narrowed it down to the element rightly though. You could get in to the machine and test it's resistance and short to ground if you have a multimeter.
elements usually sale or return ...
but when you open it up check there is no moisture/weeping at element gasket. ?
had an espresso machine where moisture near element end was the issue - the dielectric in the elements is hydroscopic
Thanks both - part is on the way but can return under DSR
Will pull the washer and check the plug and gasket when the parts here so only opening up once
It's an interested until so bit more of a faff than just pulling it out
Replacement part turned up yesterday
Pulled her out
Power and water disconnected and drain hose out / drained
Flipped her on her side and popped the maintenance hatch underneath
Photographed everything and offered up the replacement part tomake sure they matched
Real PITA getting the (looked like sacrificial) jubilee clips off
In and clips replaced with zip ties
Water,, drain hose and power back on and pushed her back into place
On the hottest (sanitation) setting and once compete with no leaks, tripping etc will ouch back into place, screw back in position and get the kick board back on
So far, so good *crosses fingers*
Thanks all for your help :D :)
Mine was a bit simpler as I just took the side off, although mines not integrated so don't know if that made a difference.
I think it varies between manufacturers and models.
Not all have the in-line heaters either - some have a looped element like an electric oven
I was looking for the money photograph with the element connection/removal ?
those connectors are reusable just need to get a flat head in the squeezed bit to open it up and then squeeze it back down (i generally use side cutters although there is a special tool)
they are one off ?, with a special crimp tool - I've used side-cutters to dismantle them , but, replaced with jubilee clips, you have the risk of either marring the rubber tube or fracturing the internal tube, by levering them off
- ones I had were on bmw washer fluid distribution hoses.
We use them on our washing machines and some dishwashers although our dishwasher heaters are corbin clips I've never had issues splaying it open.
Prising them open wasnt a problem - I wouldn't have a clue as to how (if you can) close them back up again without a specific tool
