- 23 Dec 2022
- London
Sorry this might sound like a really silly question but would these settings work with a 12600k?
Yes, the boards with the external bclk generators which can do this really expose how much these lower level chips are kneecapped by Intel. 4GHz to 5GHz all core is a decent upgrade by any margin, and benchmarks put the chip now in the same region as the much more expensive and i7/i9, at least for stuff that doesn't need more cores or e-cores.
I would say however get a decent cooler if you go this route though which is an added expense, I have a Deepcool AK500, and under full stress test the chip does get toasty even at 5GHz. To go further/higher voltage, you really need something like a decent AIO or something else top end. I also couldn't run my ram higher without some random instability due to the memory controller chipset voltages being restricted on the non-k chips, but at 5GHz with the ram at 3375, I'm laughing.
With good enough cooling and a reasonable chip (and enough volts) I suspect many of these will happily do another couple hundred MHz at least, pretty sure from memory I was able to get mine to boot at 5.3Ghz but couldn't throw the volts or cooling to get it anywhere near stable.
The 13th gen chips are faster due to the higher clocks and such, but with current pricing, the 12400 and Bclk is a very tempting option.
On that board you could try the voltage and changing the pcore multi and go from thereIm on the Msi z690 tomahawk ddr4.
Which kit(s) did you use out of interest?My 12600 does 3600mhz with no problems. It even did 3866mhz with the previous kit I had. The downside is that due to the locked controller voltage I can't change anything else.
