- 4 Aug 2007
- Wilds of suffolk
Some general solar questions just for your opinion and to help my understanding. At the moment I only have a puny 2kW system with no batteries.
Current system:
2kW setup
8 x 260W panels Trina Honey TSM-PC05A (reading online Trina are a really good brand)
2.6kW Inverter
My general questions:
- Are solar panels hot swappable - in that I can buy some 500W ones and have an independent engineer swap them out right out? Unscrew old, plug in new? A quick fix to boost my power (even though my inverter might be too weak)
- I see some 500W-540W panels for £150 approx (https://www.zerohomebills.com/product/ja-solar-jam66s30-500-mr-500w-solar-panel/). Any opinions on these new 500w panels? First time i've seen them hit the market
- See the roof: Do you think that instead of replacing the 260w panels I should get a company to install 4/5 *more* 500w panels around the edge boosting my generation that way? Or see about swapping the original 8 and maybe adding more 500w. Perhaps squeezing 7 more panels around the sides to give a total of 7500w but this may be overkill
- Am I correct in thinking that I will lose my FIT if I change my system? I'm not that fussed because really I get something like £15 a quarter - it doesn', ate a lot and we use a lot in the day.
- If I heavily add to this system will I need to fill out one of those forms for going over 4kW or are those only if you intend on giving back to the grid? Part of me is considering just filling my own batteries and forgetting the grid
- My inverter would be way too small so the suggested upgrade would be to 5kW?
I will have a bit of a crack and some here before others step in as well
Those 500w panels look like the industrial ones which are a bit larger hence higher output. "normal" size panels are into the low 400w range now though.
How old are your old panels, might not be cost effective to replace them. Just leave as is.
Looks like you could get more panels up there though if you were to push the front ones almost to the edge.
Your inverter at 2.6 would limit you fairly quickly, unless you add another full system but then your back to maybe just rip out and reinstall from scratch.
Is it deffo "your" system and not owned by anyone else?
I assume all the space around due to leaving safe working space at height. I guess some installers would be willing to work closer to the edge but then you limit access should you need someone up there for another reason.
Cheapest might just be 8x replacement panels. Looks like there is capability for some diff panel sizing there on those frames. Wider but not longer looks ideal.
8x 400s is only 3.2kw so likely most of the time your not going to be inverter capped. Then just replace with a larger one when the old one eventually dies.
You can go battery thats AC coupled so you dont need to change inverter that way.
I think your on the edge of what makes sense here. If the system functions well it might be false economy to spend a lot more now when its working, your only going to see marginal gains.
Might be better to get some quotes in, work on options, if the best is to replace all then wait until your inverter dies and then do it.
I think ronski said your allowed some changes to Fit systems but your limited in return from fit to what the old system could produce.
