whats a good External blu ray writer/rewriter please ?
5 Aug 2006
Northern Ireland
just looking for a good blu ray writer/rewriter and that can still play media as well but after looking around theres so many and on a budget so want to make sure i get a good one that will last :)
It's 25GB per layer, up to 4 layers. I'd get a Pioneer model as I bought an internal writer some years ago and it still serves me well.
I've got an asus external blu ray writer, no idea what model off the top of my head though but it looks like the ASUS BW-16D1H-U PRO.
Depending on the length of the drive you could and try and find an external enclosure for your existing blu ray drive.
thanks i'll check it, and oh man i didnt know you could get enclosures for internal drives :(
Yeah the annoying thing is, at least in the case of my internal (pioneer iirc) it was about 10mm too long for most of the ones I found... that and they can be quite pricey for is essentially a case, a small power supply and a usb to sata converter :(
checked a few but was not the right size so guess still looking for an external
