I did look at the Bofi spacer but didn't know if it would compromise getting in/out as it's fairly large at 50-odd-mm. But it's a small car and i think anyone taller than your typical Japanese will have to compromise in some way5" 11, I'm a short legs, long torso weirdoYou can get a wheel spacer for a few quid but I never found it an issues beyond not being able to keep hold of the wheel on some maximum attack stuff as I'd trap hand between wheel and leg, but I've always been one of those physics is faster than me types, and let go of the wheel on lairy slides anyway, autosolo skills and all that
Yup, meant AbarthAbarth 124 rather than the Fiat IMO, but prices are probably harder, it gets the more powerful engine mated up to the robust NC gearbox, I've been running that engine for 100k and 12 years now in my Abarth Punto Evo SS, absolutely spanked the arse off it when it used to do all my track and competition work in the early days, no bother, these day its just my little city runabout, good for 40-50mpg on a run just keeps trucking along.
That said of course it is probably very easy to get 180-200bhp out of the low power MA unit in the Fiat but not sure if lower power cars have LSD.
Yup, so you've got -NC2/3 Etc refers to the Generation of MX5? NC3.5 = 09 facelift?
Definitely not as loved as the NA/NB's but i would say prices are up on where they should be, even in the current market. Whether or not that will change, outside of the rarer editions (20th Ani, Sport Black etc), i don't know.NCs are still depreciating and they’re the least loved mx5s.
Yup, meant Abarth
Managed to nab a friends during the NC500 for a few miles and you're right, the engine isand as you say, great mpg. I think a few suspension tweaks and it would be a stonking little two-seater.![]()
If they did an RF variant and not the rare-as-hens-teeth hardtop, i would have one in a heartbeat even if the seats are so thick that it would even more of a struggle for me than my NC.
MK1 = NA
MK2 = NB
MK3 = NC
MK4 (current) = ND
Then within that is various facelifts but specifically with the NC's you have (+/- 6 months on the years due to car registration and whatnot) -
MK3/NC1 = 2006-2008
MK3.5/NC2 = 2008-2012
MK3.75/NC3 = 2012-2015
http://www.roadster.blog is a great source of info on the NC's. But if looking at NC's, you ideally want a NC2 or NC3 as the NC2 brought a load of changes which improved on the engine, gearbox (iirc) and chassis plus interior/exterior cosmetic bits. I could be wrong but the NC3 didn't really improve on the NC2 other than mostly being a cosmetic facelift update (front fog lamps are the biggest give away) along with that engine map but as said in the other thread, i couldn't tell the difference whilst test driving both but mileage may vary.
And NC's certainly aren't in the same league as S2000's but then, i'm not sure i would want to hoon one around b roads knowing that it's appreciating (if in decent condition) and i could make a decent enough return.
See.. I'd never heard of the Abarth, don't think I've ever seen one.The Abarth engines are good. They have pretty strong internals too and tune well, also sound much better than the Mazda. They will tune to over 200hp with a remap, so probably just as quick as the S2000 with the weight advantage.
I can see the Abarth 124 going up in value like the S2000 eventually.
Had a look and wish I didn'treally like the look of that.
You would assume given they're now out of production but, prices have been all over the show over the last few years - a mate picked up a mint 2016 near top spec (didn't have Android Auto) low-ish mileage (11K) for £16k winter 2020/21, did the NC500 and sold it less than a year later for £21.8k (i think he was very, very lucky to get that at the time); they're now hovering around the £18k mark for similar spec and age.I can see the Abarth 124 going up in value like the S2000 eventually.
They are great cars, drive pretty well, cabin is a lot nicer to sit in compared to a MX5, feel very Italian and sounds awesome (Had a look and wish I didn'treally like the look of that.
Definitely true, the sound alone is amazing considering what it isAbarths like to appeal to the juvenile in you so they don't do a lot to hide the noises of the turbo or exhaust and who can't say no to stickers![]()
The only difference between the engines is the multiair module, but it does reduce the reliability of it. The multiair filter can clog as well, but isn't a service part you need to check/replace it yourself.
As an MX2 MX5 owner I can confirm. Need to be proper on it with maintenance.The MX5 is great fun, but I don't rate the suspension setup on it. The engineering behind the S2000 is superior, they were much more expensive cars when they were new.
MX5 will be much cheaper to maintain/repair though. Also watch out for rust, they love to rust.
Thinking out loud and probably what i would do in your position, even though MX5's are a bit up on where they should be, it's possible that you might not lose too much when you come to sell, as long as you sell it around summer etc. Therefore, you could have some fun in the MX5 and reconsider the S2000 when finances and interest rates are a bit more in your favourSo from a sensible head point of view I think I'm sold on the MX5. But the s2000 isn't out of the question. That said interest rates aren't that exciting right now.
Unlikely to make it back but suspension does make a huge difference on them. Saying that, a decent wheel alignment (i ended up down at Wheels Inmotion) massively helps too compared to the out-of-the-box geometry.As an MX2 MX5 owner I can confirm. Need to be proper on it with maintenance.
I bought I bought some MiesteR coilovers for mine and it feels great, they aren't cheap mind £900+
Edit - Quick question for the Abarth folk, is the engine in the Abarth 124 (minus the NC gearbox) the same as the 595/695?
