Caporegime
- 8 Jan 2004
- Rutland
30 degrees and bung in some washing disinfectant.
towels 60 everything else 30. we all have very sensitive skin (delicate souls that we are) so can only use none bio and nowt much else.
since doing 1 X weekly 60 degree towel wash it has kept the washer much cleaner. we no longer battle black mould on the rubber near the door.
It is recommended to wash towels and bed linen at 60° to kill bacteria, but another method if you want to use a cooler wash is use white vinegar.
You can put it in the fabric softener compartment ,or directly in the drum (don't use fabric softener in either case) and that will help sanitize the towels on a cooler wash.
60c minimum to kill bacteria lower temps will get clothes clean but nothing more. Not sure if thats related to allergies though
Wouldn't the vinegar stink?
Towels that still smell unpleasant after washing may contain stubborn bacteria that need removing. Rewash your towel using a cup of white vinegar instead of detergent. This should kill the bacteria and neutralise any odours
white vinegar smells too, my parents flush it through the washing machine every so often and it smells like a chippy![]()
I think it was @bigmike20vt who tested the eco setting on the dishwasher (low temp for a few hrs) to the fast wash (high temp 1 hr) and confirmed the eco setting used less energy, even though it was a long cycle
I will have to ask the maid.
Aren't allergies caused by a bored immune system that's not been exposed to enough germs and dirt?Our daughter is starting to show signs of allergy, which is why we're discussing what temperature the towels should be washed at.
General question to all: if you're washing at a lower temperature than 60 and relying on a product to kill the germs, then what product is it?
