But 30c is always going to be worse than 40. It’s just some market fluff to sound green that compromises the activity of a detergent. Prob not an issue for hardly worn stuff but Im not washing towels at 30Microbiologist.
Try 60 you will be amazed lolI wash most things at 30 and it seems to do a good job, but towels seem to end up smelling so wash them at 40 which does the job
Laundry sanitizer apparently otherwise wash at 60cBut 30c is always going to be worse than 40. It’s just some market fluff to sound green that compromises the activity of a detergent. Prob not an issue for hardly worn stuff but Im not washing towels at 30
inthewash.co.uk
agh .. the new laundry sanitizer market following on on coat tails of multi-surface disinfectants to keep you family safe (double tap with killing covid certification)
It’s incredible the amount of stuff we are supposed to put into each wash these days; detergent, softener, sanitiser, in-wash scent boosters. Before long there’ll be no space in the machine for the actual clothes.agh .. the new laundry sanitizer market following on on coat tails of multi-surface disinfectants to keep you family safe (double tap with killing covid certification)
30 for everything, with Dettol Laundry Cleanser in every wash
scientific data - not dead![]()
Do you change your bed and towel everyday ?It seems to me a bit weird to be more worried about bedding and towels than the clothes that you wear directly against your skin all day. If it's good enough for clothes, why isn't it good enough for towels and bedding?
You'll certainly kill more bacteria at 60 than at 30 or 40, and more still at 95, but no washing machine will kill all the bacteria in the clothes unless you're soaking them in bleach. In the lab we use 121 degrees or even 135 degrees to fully sterilise stuff. The question you need to be asking is whether it matters. Detergents will kill a good proportion of the bacteria present and wash a good proportion of those left away, and the bacteria that are present nearly all came off your skin in the first place so even if they are there so all you're doing is putting the same bacteria back again.
A bigger worry is the growth of bacterial biofilms and mould in your washing machine if it isn't getting cleansed with a really hot wash on a regular basis.
I’m on about ability to remove marks etc. As said I work with someone who used to work at P&G who backs that up40C won’t do anything more than 30C. If your that bothered buy an autoclave.
Using virusol on your face?just spray them with virusol... it's the only way to be sure **
after foolishly using my oculus rift at the same time as having a break out of eczema on my face which had got infected I used virusol on it to good effect
** I am not a doctor or any kind of health professional![]()
Using virusol on your face?![]()
I made sure I have it a very good wipe down after spraying the headsetUsing virusol on your face?![]()
This is why some machine have towels and bedding cycles, to maintain the heat for a set amount of time, rather than just heat up to the set temperature, turn off the heater and continue the wash cycle with no additional heat.• a ten minute wash at 60ºC is sufficient to remove almost all micro-
organisms. In tests, only 0.1% of any Clostridioides difficile spores remained.
Microbiologists carrying out the research advise that this level of
contamination on uniforms and workwear is not a cause for concern.
yup eco is usually for waterHaving read the technical data on my washing machine, it would appear that the “eco” bit mainly applies to the amount of water used.
