- 19 Mar 2023
- Newquay
Hi everyone,
I'm looking to upgrade my gaming PC which I bought about 5 years ago.
CPU - AMD Ryzen 5 1600 Six-core prosessor 3.2Ghz
GPU - Asus Nvidia GTX 1060 6Gb
Mobo - ROG STRIX B350-F Gaming Motherboard
RAM - 16GB T-Force Xtreem ARGB
PSU - Super Flower 550w Platinum King
In the long run I'd like a CPU/GPU upgrade possibly keeping the motherboard if still compatible with modern CPU. I was wondering though if it was actually viable to just upgrade the GPU first and then to upgrade the CPU at a later date to spread the expense.
I was aiming at Asus GeForce RTX 3060 Dual V2 OC LHR 12GB GDDR6 which at the moment seems to be on sale, or something of a comparable price (discounted). Also I'm not 100% sure on whether the PSU will be enough. Will that require an upgrade too?
I have an 1080p monitor, which is the reason why I could play fairly well until recently with a GTX 1060, though now I can feel the system needs an upgrade. I wouldn't buy a new monitor straight away but at some point I'd like to move up to a 1440p.
What do you guys suggest? Could I start by upgrading the GPU, and maybe the PSU, and then the CPU a bit later or or it wouldn't work and should I look into getting a CPU and GPU together straight away?
Thank you for any help!
