I got some worktops and a sink.... Also getting a quartz back splash behind my hob but they cut it wrong to fit sockets so it's getting redone (and skipped!)
Have you got an internet connected fridge?
Yes it has WiFi, TV, speaker camera, touch screen, could browse Internet or whatever (never have)Have you got an internet connected fridge?![]()
If you can get a back splash of quartz I'll invest in yo ass.Also getting a quartz back splash behind
The quartz looks the damage. Such a good feature getting the cil as well. I’ll be doing the same.The after here. Its quite novel having quartz window boards also. The final finish will be tiled above the up stands which will hide the mess...
Never heard of "looks the damage" I was worried you meant it looks damagedThe quartz looks the damage. Such a good feature getting the cil as well. I’ll be doing the same.
One thing I would have done was, would have been to fit a larder unit/boiler so it would have been a flush finish Cabinets at the top. You could still go that route.
Never heard of "looks the damage" I was worried you meant it looks damaged![]()
Fair enough.Yeah for the boiler if it was me fitting/buying it I'd have it enclosed, but it's the same kitchen I bought the house with and it's difficult to get other units to match. It's in the corner of the room so fairly tucked away
Welcome aboard
Old kettle died, new one arrived.
It's a shame. You used to be cool.Nobody is going to be able to convince me away from my gadgets![]()
Depending on your kettle's spout and lid, you can sometimes position the cup over the spout so that the steam condenses inside the cup and then runs back into the kettle, thus warming your cup suitably just with the steam generated by the kettle boiling.Maybe it's because I'm not putting hot water from the one cup machine to heat the cup, before using it again for the tea or coffee.![]()
