11th Gen Intel(R) Core(TM) i7-11800H vs 12th Generation Intel(R) Core(TM) i7-12700H
If there's a decent price saving on the 11th gen, then it might be worth it. The 12th gen CPU is very good though, a good bit faster than 11th gen.
Is there much difference between these 2 CPU
11th Gen Intel(R) Core(TM) i7-11800H vs 12th Generation Intel(R) Core(TM) i7-12700H ? :confused:
Many thanks
If there roughly the same price get the 12700H, it comes with 6 regular cores and 8 efficiency cores so if you use any applications that are heavily multithreaded the 12700H is the way to go. The integrated GPU on the 12700H is much better as well and comes with 96 EU's instead of the 32 you get on the 11800H.
