This gives a more detailed spec - DOW 786 Spec. I think it's ok?
True. I will have to let it cure for a couple of days to get rid of smell. But, if that is the only issue(?) I'll pick some up tomorrow and get it done as we're crippling the small fridge in our kitchen.it might stink a bit which is where the 748 has no odour that I've noticed
Brilliant!blob away, we do![]()
I know no one with a silicon fetish, unfortunately.Lick it with a wet tongue to smooth it out.
Can't see why notI was thinking of putting some aluminium insulation tape over the top to protect it, once fully cured - would that be OK
I know no one with a silicon fetish, unfortunately.![]()
Reading your sig, I think you're probably right.It appears you do.
Hehe - they spend all that time gaming and then 'read' erotica/porn? They must have used up all their visuals stimuli gaming (unless I'm misinterpreting gamer speak).My sig is something that gamers do apparently.
Hopefully, you'll be OK.FFS I'll have to check my Samsung fridge freezer now![]()
