 - 27 Jan 2022
 - UK
You shouldn't be using QuickTimeturn vbs off and you get hacked quicktime?
Just ran a benchmark on ac vahalla and no difference.
It’s off but maybe not every game is affected by it.Then it's not off; it's actually very difficult to turn it off
Used command prompt to turn it off.How did you disable it?
i dug around and installed an old version just so I could say bonjour to some hackers in my shared itunes foldersYou shouldn't be using QuickTime![]()
				They had quite a few games in there but only one CPU (Ryzen 5800X).
Performance loss of between 2% to 14%.
This is what Id like to understand. Why does it matter if the system never moves? Is it implying this is only an issue on public networks?What does "probably minimal" mean? We don't know, but we think so?
Because security risks never change do they.... hackers never think of new ways to attack a system. Just because something wasnt possible or explotied 2 years ago, does not mean a new vector hasnt been found...My installation has had VBS off since install 2 years ago, not hacked yet!
Taking this stance to the extreme.... I never had issues running Windows XP back in the day, and never got hacked. However running XP today would be a very bad idea. Security is a constant game of cat-and-mouse. New attacks surface, new defenses need to rise to mitigate them. Something that wasnt necerssary 2 years ago, might well be needed today.Was never enabled on Windows 10 and i never had an issue with that , i'll take the frames and take my chances with VBS turned off like i had previously on Win 10![]()
It was off by default upon install so why the sudden hoohah about it?Because security risks never change do they.... hackers never think of new ways to attack a system. Just because something wasnt possible or explotied 2 years ago, does not mean a new vector hasnt been found...
Because attack vectors change? Keeping an OS secure is always changing.It was off by default upon install so why the sudden hoohah about it?
