Got my install yesterday. It is a relatively small 10 panel system, split over 2 roofs, with a 6kw battery (2 x 3). Despite doing as much research as a I could and picking a local company that has been in business a long time I still have some misgivings as to how they fixed the rails (it is a slate roof). They screwed on brackets to the rafters (through the slate) then used a lead replacement product to slide in under the slate above and wrap over the bracket. I wanted them to remove slates and attach directly to the wood, then reslate around it, but they said they do all of their slate roofs like this and it meets code. I guess it is better than just siliconing the holes, which I have heard of people doing. I will just have to keep an eye and get it done properly if I have any leaks. Other than that the team were great, really hard working. It cost just over 11k for 10 panels, optimisers and the battery, with a 5kw hybrid inverter. It needed 2 lots of scaffolding. It is all solarx gear, with pearlite 415w panels.
Was just watching this video and thought of you.
. I may have some issues in a few years, but for now everything is fine, no leaks and no movement even in high winds. I have all the certification, which shows what that is worth! Once I have issues I can just get decent roofers to refit the brackets properly; all the electrics are done well so there is that at least!
