Browser games or all games?Since Edge got updated i found all games to be throttling card and a lot crashes and freezes too. Found out it was efficiency mode in performance which was turned off. I turned it on and games are running normal now.
Oh okay, do you have Edge open when you game or is this background processes?When i say all games i meant just normal PC games i never play browser type games but this update has a lot problems.
Seems a bit extreme... I would rather just make sure you turned off startup boost and continue running background extensions in Settings -> System and performance to make sure it's actually not running when closed.No. I always make it a point to restart PC when ever i go to start a game.![]()
Don't know if this has been posted anywhere yet.
After Edge updated and i found it had created a new toolbar button that i did not want and could not remove.
I found a vid showing a way to get rid of it.
You can just remove it in settings nowI'm not a huge Edge user. I only reinstalled it about a week ago. The video in the OP worked for me for about a day, then the Bing button was back again. I found this simple reg edit online this morning and it worked straight away. Didn't even need to reboot my PC. Time will tell how long it lasts I suppose.
