Dishwasher has finally died. Spec me a new one..
Went for a Bosch SMV4HVX38G in the end. It washes dishes, dries them. Sorted.
Good good.
I find the 65min cycle does things well for everyday use. Eco cycle is 4+hrs and is good if you have an overnight cheap leccy tariff.
Aldi triple chamber capsules are the tabs to go for, as they clean everything thrown at them and are cheap as chips comapred to the branded competition (Fairy). I also use some rinse aid (sainsburys own brand) and in our very hard water area, all the glasses come out sparkly and dry.
Good good.
These ones?
I've been looking for some alternates for ages and they all seem pretty poor in comparison to Finish.
We use whatever salt as salt is just salt really, but also Finish rinseaid so will try the Sainsburys one too.
These ones?
Yep those ones.
I've always been a fairy user, but tried these and they rock. The block type tabs from Aldi are not as good and do leavea few stains here and there.
It's not always down to the tabs though, you definitely need a dishwaser with good drying function (heat exchanger).
Yep those ones.
Picked these up and so far so good. Significantly cheaper than what I was getting before.
