New Asrock DeskMini Fanless
1 Nov 2004
Intel Celeron Processor 4205U
What a crap CPU.
For an Untangle or pfSense box it’s perfect. In fact, it will probably be a very nice PC for someone you just wants to browse the net and do a little word processing in silence. That Celeron CPU is actually pretty decent.
FanlessTech that originally suggested the idea to Asrock are not happy about it by their recent tweets and as someone pointed out on reddit you can buy a better spec Arm boards for the same money.
Aside from upgradeable RAM not sure what this offers over many other fanless mini PCs with much better CPUs.
Yes and no - it is quite strong for a dedicated system primarily doing a specific task but chokes quite badly for more general purpose stuff.
I've been using the MeLe series of fanless mini PCs - aside from not having upgradable RAM which potentially could be a benefit they are pretty decent little systems in a decent form factor not much bigger than your average router with a full Windows experience (or can put Linux on, etc.). Perfect for general network services as they use very little power at idle.
Jesus the AMD 7 series APUs make this look like a pocket calculator. 2c2t at 14nm and 12.5W TDP - get out of town.
I guess this is aimed at industrial use with the COM ports. 8.2W idle and totally fanless is actually pretty impressive if it wasn't for such an ancient CPU.
Actually got fairly strong performance if you are doing something heavily single threaded in a network services type task - but yeah does not cope well if you are doing something multi-threaded. The other Intel variants like the J4125 aren't hugely slower, better at multi-threaded stuff, and use quite a bit less power idle or even the N5105 if setup right for low idle power.
Originally a few years ago the Deskmini Fanless was supposed to be based on a 35w cpu with a twin lan socket as the idea came from people who were successfully using the Deskmini series with Arctic's Alpine Passive CPU coolers, the only hassle was the need for a hole to be cut in the top of the case.
Shame the 1235U struggles under passive cooling and is performance limited by the TDP otherwise ideal for this kind of setup.
Shame the above board uses a engineering sample mobile CPU as it looks like you get a lot for the money though it maxes out at 80w so that's not going to be passive unless you undervolt it.
