- 2 Sep 2013
Tried it on different system on same network, got a B for Firefox this time, and C for Edge. But this system is weaker than the main rig, so the B is expected (It uses one of those old cheap and dirty Qualcomm Atheros gigabit connections on the motherboard that basically dump everything onto the CPU and the secondary system uses an i5 3570 (non-K) so it has it's work cut out normally anyway).Did you repeat the test a few times in both browsers, to confirm the difference was the browser and nothing else? There are loads of variables here - different browser engines, tracking protection, SmartScreen, extensions etc etc. That's before you even consider the fact that no two runs will be the same, as your local network, router, and the wider Internet will differ from microsecond to microsecond. I'd run it again a few times, and if it averages out start looking at your router. If the test keeps showing Edge is ****, then switch to Firefox like the rest of us I suppose.
And yes, tried it a few more times on main rig. Firefox is OK with an A, it's once Edge is used it becomes a C. So users need to be aware that browser difference can make very differing results come up.
