Replacement O-ring/Gasket for Barrow D5 Pump Top
1 Nov 2011
Portsmouth
Hi all,
Could anyone help me source a replacement O-ring for my Barrow D5 Pump/Res? It's the one that sits between the pump top and the tube reservoir:
Trying to find out the actual dimensions is proving tricky - one source states 57.5mm x 3mm, another suggests 60x3mm...
Grateful for any help, thank you.
57.5 x 3mm
the 60 x 3mm is OR ( outer radius ? ) same O ring
Google ' Laing D5 O ring ' you'll see a few for sale, but competitors so cant link.
57.5 x 3mm
Much appreciated - I found a supplier on eBay with those exact dimensions, so fingers crossed it'll just drop in (it was about 60p more to order 5, so I'll have spares).
I got an email back from the company I bought the Pump/Res from (a competitor that specialises in Watercooling, also in the UK), when I asked if I could either a) purchase a replacement gasket or two, or b) have the exact dimensions to source one, and was disappointed by their curt, unhelpful response.
Sad, because I wasn't asking for nor expecting a freebie, just a little aftercare. Lesson learned...
Emailed Barrow who are sending me a couple of replacements without charge.
I received my eBay order of 57.5mm (internal diameter) × 3mm and they arrived very quickly. Put one in the little recess of the pump top and (so far) working well. No drips, leaks or fluid loss, for a 2.80 part..
The O-ring could probably do with being 57.5mm by 3.5mm, but in a pinch, the smaller size does the job.
