This might be a stupid question but can I play cd's on this
Just a FYI: you can get external players, they're not much more than internal drives and it gives you far more case choice (because most cases don't have optical drive slots anymore).
As above. I've been using this option for the past ~10 years to have more choices in cases and to keep my laptops lighter - for the rare occasion i use an optical drive.Just a FYI: you can get external players, they're not much more than internal drives and it gives you far more case choice (because most cases don't have optical drive slots anymore).
Really like your build options, think I'm set on the 6700 XT for price vs performance.nah, this is best price/performance...nothing to improve unless spending significantly more
yeah, since covidam I right in thinking that Overclockers are online only now ?
Is it still Newcastle under lyme areayeah, since covid
they've just moved to a new warehouse too
yeah, nearby the A500Is it still Newcastle under lyme area
I went with the recommended spec entirely but I have a small problem with fitting the front intake fans to the Raijintek arcadia11 case, simply I can't see how to remove the front cover or an alternative way to screw on the fans even though the pics clearly show 2 fitted to the front. I've done many searches and can't find how (although I'm not great at searching) any advice as everything else seems to be under control so far and everything has fitted well I think for a first timers build
a good yank outwardsPull outward or more of a slide upwards ?? Cheers again Tamsy
they've done free deliveries for the ST postcode for quite a while now lolJust in case you were wondering why the 2 month delay, Overclockers just reopened for in person collections 1 mile away
should test the parts outside the case first just to make sure all working before you install into the caseThe congrats may be a bit early but I have installed everything into the case, now to plug everything into the motherboard and then the really hard part begins when I workout how to get stuff on it (windows etc) and setting it up
