Poll: Ryzen 7950X3D, 7900X3D, 7800X3D
Will you be purchasing the 7800X3D on the 6th?
  • Total voters
    191
  • Poll closed .
I expect a whole bunch of reviews to say it's basically the same as the simulated 7800x3d with some flavour added by mumbling about the benefit of it being a single chiplet and how its a much better gaming buy than either a 7900 or 7950 but still expensive and not a value for money part.
the review slides have been leaked
It's quite interesting to look at the amd 30 game benchmark slides and compare them between the two CPUs
I've skimmed over them and noticed that in some games, amd shows the 7950x3d performing 5-8% faster than the 7800x3d, there is also games where they show the 7800x3d performing 2-3% faster than the 7950x3d. The games which show the largest variance seem to be the games that are most latency sensitive and single thread heavy - for example in counter strike they show the 7800x3d losing to the 7950x3d by a good margin which suggests the 7800x3d has lower clock speed
Overall and slides suggest the 7950x3d is faster overall and the slides show that the 7800x3d loses to the 13900k in some games where the 7950x3d beats it
Yeah but that's a full 7950X3D not a simulated 7800X3D by disabling the frequency chiplet.
It will be interesting to see the reasons why a full 7950X3D can win and why it can lose against a 7800X3D. That will probably be a lot more interesting than the regular review of a 7800X3D.
Had fun building, testing and comparing my 13900k and 7950X3D with my 4090 Strix the last week. TLDR is, pretty much identical gaming performance overall, though with the 13900k consuming 100-180W (depending on game) and the 7950X3D 60-70W. Amazing level of efficiency and IMO AMD win this round by a large margin.
Had no issues, crashes or drama of any kind, just Intel levels of stability.
Few pics
I had to do a double take when I realised it was Dave that went AMD :cry: .. Nice setup and happy to see you are seeing the benefits :).
Am I the only one that dislikes the IHS on the Zen 4 Ryzen chips? It's just so... fiddly. I don't see what purpose the design serves, other than possibly reducing surface area.
I prefer it over Intel's LGA1700 - having to spend £10-50 (depending which type you get) on a contact frame for optimal performance/thermals is not a good thing.
@LtMatt You have TLOU? Up for some testing? Im interested how the 3d CCD compares to the non 3d in this game. It's the heaviest - in terms of CPU - game i've played. It dwarfs cyberpunk in CPU usage and power draw
:D I've not used a LGA1700 CPU, but that doesn't sound good either. But that does make Zen4's good. What was wrong with Zen3's design?
Zen3 (AM4) had pins on the CPU, this caused many broken CPU's (bent pins) due to user error/accidents etc. AM5 CPU's moved to LGA (no pins on CPU, pins on motherboard socket) and have different physical characteristics, so required a new IHS design. Lots of surface PCB mounted components as well. Also complicated by the fact that they wanted to maintain cooler compatibility with AM4, so had to make it thicker/taller than it needed to be perhaps.
It works well in design though, as long as you don't put too much thermal paste on, or things will get messy :D
I just don't know why they needed the cutout sections.
The cut-outs are because of the need to work around the surface mounted components.
Doesn't look like there's anything at the "top" that they have to work around. Could they not have just made it a bit smaller so those bits are outside of the IHS?
Yeah it'd reduced the surface area a little more but it'd make it less fiddly. They don't seem that concerned about surface area anyway.
Of course not just about cores and yeah IPC is a big one and even more important.
Though someone 9900K can still do fine with minimal bottlenecks today at 4k with A 4090 where as if they had an 8 core 6900K or Haswell-E 8 core with 15% worse IPC, they are going to struggle.
Thing is Raptor Cove has top of line IPC today.
Yes Zen 5 down the line will beat it by 15-20% in IPC. Zen 5 is going to beat Zen 4 by 20-25% in IPC. Since Raptor Lake P cores have 5 to 10% better IPC than Zen 4 and Zen 5 will beat Zen 4 by 20-25% UIPC, it stands to reason Raptor Lake P cores will be 15-20% behind in IPC.
Unless video cards are so severely bottlenecked at 4K that 15-20% IPC is not going to break my 13900KS in games.
Just like today, Ryzen 5000 has worse IPC than Golden Cove and Raptor Cove by 15%, yet iut spanks Coffee Lake IPC by 19% so those who purchased Ryzen 5800X 2 years ago were well future proofed for RTX 4090 at 4K as it runs that very well with not bottlenecks.
So I got much better IPC than Zen 3 and much faster clocks so I should be good at 4K for next GPUs.
Though if going below 4K every CPU in existence is a bottleneck for RTX 4090.
This. I mean i am running 9980xe at 4.6ghz all cores and ut just doesnt have the grunt anymore to compete with current gen cpus especially when they are running near 6Ghz.That combined with the massive IPC gains since means with a 4090 there can easily be 20-30 fps difference in games.
Oh plus one for this. Especially at 4k max settings please.
Ive never really understood tech tribalism.
100%, go with whatever suits your needs. It's the same with the red vs green but anyway I digress.
I was hoping we'd have at least some more info on the 7800X3D now but I guess it's locked down tight until the 6th. Why couldn't they do it in the financial year :(
Hoping to snag a preorder asap, but we'll see if the launch is as 'messy' as the 79XX.
I'm still undecided if it's worth it purely for 4k gaming from a 7600x. I think its a average uplift of +9% according the simulated results.
