Does the Asus ROG Strix B650E-E Gaming WIFI support USB C Power Delivery.?
31 Dec 2008
As in the title does anyone know if this motherboard supports usb c power delivery standard on the front panel usb c port.?
So far I found one youtube review claiming that it does up to 30W.
Asus website doesn't say nothing about it anywhere.
I know that high end asus motherboards support it up to 60W and require 6pin pcie cable plugged in next to the usb c header but those are £200-£300 more.
Here is the youtube review I found, he mentions 30W usb c pd at 10:31
Manual says it’s a 10Gb Type-C port, does not say anything about power. My case is old, so I don’t have it connected. I would say it’s not 60W as it has no extra power connector.
No I know it's not 60W as It doesn't have the pcie power connector but the review claims it has 30W.
I forgot to add the review video to my OP so updated it now.
Also the review says it is 20gbps port which is not what Asus website says as you @FredFlint pointed out.
Yes, it has a 20Gb and 10Gb Type-C ports on the back. I only have one Type-C thing, Pixel 4 phone and when I plug it in, it says "Charging Fast".
math symbols keyboard
I want it on the front panel and also usb c port without power delivery should supply 15W (3A@5V) and a lot of phones will take that as fast charging so that doesn't tell me much.
So I understand you own and use this board..? if so are you happy with it.? is there anything you wish the board would have that it doesn't.?
Thanks...
I want it it on the front panel and also usb c port without power delivery should supply 15W (3A@5V) and a lot of phones will take that as fast charging so that doesn't tell me much.
Thanks...
The boards been great, not had any issues so far. I don’t use WIFI/Bluetooth so have not tried them. I just disable them in the BIOS, would be good to have a cheaper version without WIFI/Bluetooth.
Absolutely I don't understand why most boards include wifi (bluetooth can be useful) as this is complete waste of money for most people on a desktop pc.
