I will get the build out the way first:
NZXT phantom 410 case, very yellowed and broken power button.
Asus p8z77-v motherboard, sound not working through case or outputs(works on hdmi) wifi not working(pcie card installed)
Intel i5 3570k with slight overclock
Corsair h100i cooler
8gb Corsair vengeance ram
Sapphire r9 280 dual x gpu
6x 120mm fans, 1x 140mm
Corsair ax750 power supply
Samsung 128gb ssd
Ocz ssd
2tb hdd.
It is a very old spec that I need to upgrade, I don't have a massive budget and am not worried about buying upgrades over time. I play games and starting to 3d print and design soon.
Question time:
1. What would be the best bang for buck £300ish upgrade I can do now?
2. How future proof can I make it?
3. Spend the extra and ddr5?
4. Motherboard, cpu, ram and gpu to go for? I will probably not upgrade the motherboard and cpu for another 5 years or more. The gpu I will upgrade.
What do I go for motherboard and cpu combo about £300~ can push if you think its worth it
About the same cost for gpu? What to look for?
My system is a mess and I feel so lost with pc tech as haven't looked into it for years.
Thank you
Lee
Samsung 128gb ssd
Ocz ssd
2tb hdd.
Question time:
Thank you
Lee
