Haha I do back in the UK just not here in Spain.If you own a Jeep like this and don't even have a massive socket set, you should really be questioning your life decisions![]()
Fixed that this morning though.
have you found any online wiring loom description (haynes etc) to confirm purpose of any wires ?
headlights will be on a relay with the higher current they use(or are they led), so maybe you somehow fused a relay, usually plug in thumb sized blocks somewhere that wiring loom desc would reveal,
can maybe swap relay blocks between fogs&high-beam temporarily to test any theory.
e: https://wranglertjforum.com/threads...ice-manuals-fsm-technical-documentation.4618/
hadn't realised - that underside look incredibly good nick - where had it lived it's life - nowhere with salt.All things i guess need to accept on a 25yr old Jeep,
bit lower mpg in return for reliability of a naturally aspirated engine - automatic too?
Got some side steps so that my wife can get in easier
Stupid stupid country. I wish i lived in the USA!
I figured since i was laying sound proofing in the tub, it might be a good idea to replace the carpets given they're 25yrs old. People rave about something called Bedrug. It's waterproof and mould resistant so ideal in this scenario.
Buy it in the USA for €400, so about just over £300 at current rates.
I can find them in a single store in all of Europe which is based in Germany. €620 on there, plus €100 shipping to me in Spain. So just over double the USA cost. I had thought about creating a huge order in the USA as there's quite a lot i want. However the one company which has everything quoted me €2400 in postage costs!
Hopefully means the worn bolster starts being on the "low traffic" side and you get a fresh bolster to start rubbing against!No rips and just need a wipe down. One thing i hadn't thought about at all was the different between LHD and RHD seats. I'm hoping there's no material difference and i can just switch them around!
just a thought - they have pyrotechnic pre-tensioners ? that will be compatible with the jeep - or, you transplant the mechanismAnd i have my seats. Out of a Hyundai Coupe but from a few articles i've read, they're a good fit for the jeep. Not bad for £100
Chuck a cover over the car, that sap will eat away at the lacquer and any fabric it gets on.parked up under loads of pine trees at my parents.
( having removed seats from a bmw way back ensuring these don't fire when you are manhandling seat - a tab + disconnecting battery first, was main concern,
wondered if they could break your arm/fingers )
Also, it's a proper pita to remove.
Literally calling you a pleb.his car is more important
