i know it says 10 - 15 days build time, but what are the odds of it pc's been built and send out early? just exited sorry hahaha
Not sure but I do hope you enjoy your new PC very much when it arrives.
I saw on another thread you are getting the Tritium OCUK gaming rig. I do recommend you ring Overclockers and ask them to swap out the 3070ti graphics card that comes in the Tritium to swap for a 4070. I suggest the Palit 4070 dual which is a better graphics card and recently released that costs the same or perhaps £50 more depending on which 3070ti they had in mind for you in the Tritium. Hopefully it wouldn't cost you anything! There's a link below to the Palit GeForce RTX 4070 Dual :)
Link to Palit 4070 dual on Overclockers UK
I would say it’s good odds, perhaps not great odds, better than no odds at all. Possibly, somewhat unlikely, who’s to say, how long is a piece of string?
When it does arrive…enjoy! What spec did you go for?
It has a 3070 ti - i5 13600k - 32 gb ram :) what do you think of these specs?
I'v edited my post above to recommend a different graphics card, I hope this is useful to you and causes you no inconvenience or upset.
There is also this 4070 based prebuilt if OCUK do not want to play ball with the swap out for £100 less than the Tritium and you are OK with the AMD processor rather than the Intel one in the Tritium. The intel 13600k is a better processor than the AMD 5600x so the difference between the two is a more complex judgement without both machines tested side by side.
OcUK Gaming Gallium
If anyone else would like to comment on those suggestions I would appreciate the wider views.
Thanks for the help! Im working during there opening hours? Do they have an email which im able to talk about this on?
web ticket at the bottom of the below page
Hi mate just updating you I was aloud to swap it for the 4070 at no extra cost :)
That's super good news. The Intel 13600, 4070, 36gb ram and NVME drive is a great system for 1440p gaming, which games you planning on to start?
BTW braided cables as well, fancy!
Hi Brenny, just to say I have recently gotten the same card, there was a bit of a whine when games are running that I only just noticed. (a buzzing sound that dissappears when you go into a games menu). I downloaded MSI after burner and undervolted it to 910mv at 2475hz and it reduced it to hardly audible, there is a video here
it was easy to do. Perhaps your card wont have any whine at default voltage anyway, I hope. it might even be my PSU, it's 15 years old!
