Self propelled lawnmowers - WHY?
Don
18 Oct 2002
Notts
Just got a new petrol mower and it's a self propelled one, didn't buy for that reason but didn't realise how useless it is for normal folks
Pull the lever and you are off round the garden like the Keystone Cops and forever stopping and starting to turn round or do small bits
Unless you are either/both frail or have a football pitch sized garden are they any use? will I get used to using it?
At moment thinking of disconnecting the cable to the lever
Not even heard of self propelled ones TBH.
I have a Qualcast Classic which is self propelled, it has the large and very heavy drum (so you get stripes).
I wouldn’t want to be pushing it as it’s way too heavy. It’s OTT for the amount of grass I have but it was free, just needed a carb rebuild and blade sharpen.
If I had a big garden it would be awesome, but I’d be forever emptying it of cuttings, so swings and roundabouts really!
I wouldn't have manual one. It's too annoying having to turn around when the mower can do it for me.
Also for mine the propulsion is on demand. I don't need to use it. (but that would be stupid!)
Probably not very beneficial in an average garden no.
But used to live in a place which was 3/4 acre of land, most of the garden was lawn and only a small amount was level and some was outrageously sloped. Not uneven just sloped.
That's a great time to have powered wheels on the mower. Still shovelling tons of clippings but at least the mower manhandling is greatly reduced.
You need to stop faffing around with half measures and get a proper self propelled one, non of this faffing around having to walk it around it nonsense :p
Serious question, is it clever enough to dodge cat poop or would you have to painstakingly clean it out?
for those saying don;t use the SP option, that's what I am trying to do but while pushing you hit the lever and it's off like Usain Bolt
It doesn't dodge it no, but i've never found it to be an issue with mine and there are lots of cats around here.
Even if it did get some cat muck on it, you never need to go anywhere near it so it wouldn't matter.
What about actively mowing cats?If it did that i would buy one in a second :D
