TBH that's not an outlandish suggestion.Move
Jet wash first?
You need to embody your inner knuckle dragger. It's just dirt and holes; you don't need to be under pressure to get it done in 2 days or whatever a trade would either.Yeah makes sense.
I also need to jetwash/weed the front block paved driveway and then that will need re-sanding too. It's got some depressions where the car wheels tend to sit.
Damn this back patio. I'd really like to improve it more but I'm worried that once I start pulling up slabs I'm going to be in a mess I can't solve.
Not a bad idea. Say lift in sections you can easily complete in a day, lift, sort sub base out and refit slabs. The only issue would be having to hand tamp instead of getting a whacker plate in there if doing it piecemeal.You need to embody your inner knuckle dragger. It's just dirt and holes; you don't need to be under pressure to get it done in 2 days or whatever a trade would either.
Do a section at a time and take your time?
You'll need to lift and fix the sub base if you don't want it sinking again. If you get someone in it won't be cheap.
I don't think you'll get away with this. You need to lift more and relay in one direction.Trying to refit the block pavers neatly and some are a tight fit but close. How can I shave off a couple mm from a brick?
Take lots of photos, pull everything up, pressure wash it, and re-lay it. Hire a compactor to make sure it's laid correctly. Will only cost the compactor and a bag or two of ready mix.
... And obvs it's meant to slope away from where you don't want water.Check out Wickes - their delivery is normally decent. (For bags)8 bags of sharp sand gone down, can barely notice it.
How many bags of sand can I safely transport in a 3 series estate?
I'd order some, but with delivery a bulk bag seems to be about £100 and I'd have to barrow it all round from the front to the back (plus I don't have a barrow). Bags will be easier.
I did, it initially said free delivery once I passed £75 total value, but then when you get to the basket they want £30 to deliver.Check out Wickes - their delivery is normally decent. (For bags)
If you are going to jet wash it, try and source some sodium hypochlorite.
Its upto you how strong to mix it but i usually mix it 1:1 with water and add it to a pressure sprayer and spray the patio first before jet washing.
Really helps to lift the grime off slabs and blocks.
Ah annoying - I've ordered large sheet materials and delivery was 7 quid.I did, it initially said free delivery once I passed £75 total value, but then when you get to the basket they want £30 to deliver.
Looks good to me!Progress photo from today's efforts. That sand you can see there is 8 bags. Plus Ive remodelled the part near the top step. Im using the wall as my guide to get it to look level against that.
