Small cars can fit rear facing seats?What sort of miles do you do? If you don't do many surely you'll end up with all sorts of issues with dpf. Also how was your mps so poor ar mpg, even my wife's old focus st was better than that and we thought that was poor at the time. And I'd be worried about the battery/motor on the model s, I thought the warranty only last 8 years anyway so it might not be milage that causes it to expire. Thinking about it, that price point must be 80% of the used car market, even small cars can fit rear facing carseats (unless you mean i-size as I think they are a bit bigger).
Model 3 has less rear space. Not suitable for my needs. Plus, don't really like how they look. Amd out of budget.Newer car seems the obvious choice. If free charging/fuel saving is the main contributor why not consider a newer model 3?
some employers do it as part of a green campaign. as of a few months back our place stopped handing out access to the FREE charge points and now are just for visitors or emergencies but staff still have access to a bank of charge points at only 14p kWh...What does it cost to charge a Tesla at commercial electricity rates and why is your employer happy to pay that for you?
My office rate is 21p per kwh. I negotiated the rate on a 4 year fixed rate just before it all went to shiz.What does it cost to charge a Tesla at commercial electricity rates and why is your employer happy to pay that for you?
I've learn that upgrading to the digital cockpit on a 435d Is a 1k purchase, and can be done myself. Makes the 435d I'm looking at even more attractive
But... it looks cool! Why not have fancy bells ehIt's not worth doing at all. It doesn't really do anything the standard one doesn't.
I think the main difference, aside from the obvious style changes between sport/eco, is that the increased spacing in the centre allows for the detailed navigation details to display between the dials. Not sure the 6WA cluster on the F3X does that?It's not worth doing at all. It doesn't really do anything the standard one doesn't.
Then you are stuck using the built in nav versus Waze. RipI think the main difference, aside from the obvious style changes between sport/eco, is that the increased spacing in the centre allows for the detailed navigation details to display between the dials. Not sure the 6WA cluster on the F3X does that?
It's just a nice thing to know I can do it.Overall though, back with Fox's original point - whilst it's nice to have, I agree with the value sentiment, i'm not sure i'd spend £1000 retrofitting it myself if it wasn't already in the car.
No you are talking rubbish, my Mrs had a fiesta and we were fine with a rear facing seat and I managed it with a 911. You are talking about i-size, not a standard rear facing as normal rear facing is to around 2 years old. There is a difference. Why not put them in the front and disable the airbag? I'm sure you could get a smaller car but you clearly have already decided on 2 cars from the opposite end if the spectrum imo. If a car can fit an adult in the back, than a car seat should be fine too, unless your Mrs is 7 foot tall.Small cars can fit rear facing seats?
Sorry, but you're wrong.
There is fitting, and then there is actually fitting.
Don't forget, rear facing seats can be used till 6 years of age. The child needs legroom, so the seat is right at the ledge of the seat.
The passenger seat will be completely unusable in this situation. Therfore the car can't accept a rear facing seat (in my view).
The MPS I had, the wife could NOT sit in yhe front passenger seat for more than a few mins. The seat was bolt upright, slammed as far as it could forward so to accommodate the rear facing seat behind.
Then there is even getting a baby seat behind the drivers seat. Don't make me laugh, impossible.
I've test fitted my pair of seats in 12 different cars. The ONLY ones where both kids seats fit and the passenger seat was still useable was in the Model S and the 4 series Gran coupe. (Othwr BMW models will also allow this.. however I don't like the look of them)
Of course, there are plenty of cars that also allow this functionality, a Audi Q5 for example. But i don't like them.
So... please don't say that small cars can take rear facing seats. As that is absolutely un true.
Not such a big issue in the UK. There were major issues with the early models being left at 100% in very hot temperatures (40c+).The Leaf is known for having terrible battery degradation because there is absolutely no active thermal management.
On the other hand Tesla generally does a very good job at looking after the battery - 50% degradation after 100,000 miles sounds like complete nonsense.
