No you are talking rubbish, my Mrs had a fiesta and we were fine with a rear facing seat and I managed it with a 911. You are talking about i-size, not a standard rear facing as normal rear facing is to around 2 years old. There is a difference. Why not put them in the front and disable the airbag? I'm sure you could get a smaller car but you clearly have already decided on 2 cars from the opposite end if the spectrum imo. If a car can fit an adult in the back, than a car seat should be fine too, unless your Mrs is 7 foot tall.
I might have missed it, but how far are you driving?
I'm not talking rubbish at all.No you are talking rubbish, my Mrs had a fiesta and we were fine with a rear facing seat and I managed it with a 911. You are talking about i-size, not a standard rear facing as normal rear facing is to around 2 years old. There is a difference. Why not put them in the front and disable the airbag? I'm sure you could get a smaller car but you clearly have already decided on 2 cars from the opposite end if the spectrum imo. If a car can fit an adult in the back, than a car seat should be fine too, unless your Mrs is 7 foot tall.
I could not fit a baby seat behind the drivers seat in a Mazda 3.
The rear facing MiniKid seat made it so the passenger front seat was not possible to sit in. The ONLY person I know who fits is a 5ft7 chap. And he moaned that the seat position gave him back ache.
Like I said, the only cars that I've tested so far that meet my need for the rear facing seat (up to 6 years) and the baby seat are the ones ove specified. (The ones I like anyway)
I'm looking at the BMW as a better choice now.
I do 8k miles per year, and I don't need to be told that a D isn't suitable for that. I know, and don't care.
