- 19 Oct 2010
Hi
A parent at our local school posted online asking for help upgrading their sons PC. They have zero technical knowledge so needed help. I usually ignore these type of posts but I felt sorry for the guy. This was the sort of advice he was engaging with....
Anyway, I DM'd the guy an olive brance.
The kid has "about £250" but they will also help him out. This is the PC: *Edit, see below* and he is struggling to play Jedi Survivor.
I've suggested a 5800x3d and a matching 8gb ram stick taking him to 16gb.
Current unknowns are the PSU spec and Cooler spec. Potentially they might need an upgrade too?
What do you think, how would you slice this cake?
Cheers
Is it just the RAM chips he wants to upgrade or is it graphics chips and sound card etc?
RAM is quite easy, as long as the motherboard has the slots, or he only has SIMM chips, and can fit DIMM ones, graphics and sound are ornally plug and play replacement PCI cards, again easy enough. If he wants to get into though, I suggest getting yourself a "clean room" type area and an anti static strip for him to prevent damaging the components!
Cheers
